Need help striping my garage.....
mile2424
Hi All,
I need some help or suggestions on the best way to go about striping my garage walls with some vinyl striping. My main question is how can I make sure I get the tape level and straight. I know they have these laser levelers out there, but A.) I don't have one, and B.) Wouldn't I need to put it on a tripod or something to get the correct height down? All suggestions or idea's are much appreciated!
z28snksknr
Turnersville, NJ
Pick a corner or the best place to start (near the garage door or entry door maybe), make a mark where you want the tape to be, and use a level to scribe (in pencil) a level line around the garage.
Just place the vinyl tape edge on the line and you're good...
I did the same with painter's tape and achieved excellent results- straight as an arrow.:thumbup:
mhm993
Gravity has always been your friend. Either use a string line with one of those hanging little spirit levels to set two points, or use a water filled tube to get two level points. I'd opt for the little $5 hanging level. Snap your chalk line, making sure it intersects both points,and voila, you have a perfect guide line, with no tripod, no lasers, and...well, you get the point.
buening
Decatur, IL
Snap a chalk line after you get rope level with a line level? You'll have 3 walls done and will see how far you are off at the 4th wall. Chalk is easily washed off.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You can rig up a water level with a bucket and some clear vinyl tubing. Or get a 6' level and take your chances going around the perimeter, but probably the easiest is measure down from the ceiling at different points then connect the dots with a straightedge. Don't measure from the floor up, if your floor has a slope to it.
rwhite692
Central Valley, CA
I have never seen vinyl striping applied over drywall that did not eventually peel/curl...Don't know why that is...We tried it at one time, over drywall that had been painted with a nice semigloss finish which we thought would be a good base for vinyl striping...within 6 months it had let go all over the place...and it was the good 3M stuff.
It may have to do with the amount of thermal expansion/contraction, or something...My opinion would be to go with a painted stripe.
inurface
rochester, ny
Paint it, it's easy and probably cheaper. One of my coworkers had a black decker 360 laser level that makes the job super easy!
Notch1988
Fort Saskatchewan, AB, Canada
Hmmm... I'm planning to put up plywood for the bottom 4' and drywall up after that. Was hoping to use a vinyl stripe to cover the transition. I wonder if some PL premium will do the trick to hold the vinyl on.
