JonDick13926
I pulled a window motor out of a minivan about a month ago because under a load it wouldn't spin (it basically wouldn't move the window up and down) but would spin fine unloaded.
I replaced it and the new one worked fine, and I sent the vehicle out the door. But I kept the motor so I could mess around with it later and try to figure out why it failed. I took it apart and didn't see anything obvious (obvious to me anyway). The brushes and commutators looked good. The coils looked good (though I'll admit I wasn't 100% sure what to look for). Finally, I scoped the motor and graphed the amperage, and the graph was rough. Each ripple for each commutator looked different, and none of them looked as good as you would expect from a healthy motor like this. Obviously this motor is bad, but I'd like to understand specifically why this happens, as in where in the motor does this fault originate and why does the motor seem to lose the torque it once had?
