Jeff
Hey Guys...the hand-me-down air compressor I've been using just ain't cutting it any more. I need something that can handle grinding and sanding when I start a small restoration project this week.
I understand the basics: CFM vs HP vs Capacity vs Drive Type. I can't afford one of those $1500 IR compressors. My budget is $500.
I found this compressor at Lowe's, with disc/tax out the door is $456.
Advice? Comments?
________________________________________________________
Here's the description and specs from Lowe's:
3.7 HP 60-Gallon 155 PSI Electric Air Compressor
<table><tbody><tr><td class="lcol">UL Safety Listing</td><td class="rcol">No</td></tr><tr class="shade"><td>CSA Safety Listing</td><td>Yes</td></tr><tr><td class="lcol">ETL Safety Listing</td><td class="rcol">No</td></tr><tr class="shade"><td>Gas or Electric</td><td>Electric</td></tr><tr><td class="lcol">Horsepower (HP)</td><td class="rcol">3.7</td></tr></tbody></table>
<table><tbody><tr class="shade"><td>Tank Capacity (Gallons)</td><td>60.0</td></tr><tr><td class="lcol">Tank Type</td><td class="rcol">Stationary</td></tr><tr class="shade"><td>Air Compressor Voltage</td><td>230</td></tr><tr><td class="lcol">Amps (Amps)</td><td class="rcol">15.0</td></tr><tr class="shade"><td>Warranty</td><td>3</td></tr></tbody></table>
Advice? Comments?
- This one air compressor powers all the tools you need for woodworking and auto restoration jobs
- Finish over 100 jobs such as automotive spray painting, automotive sanding work, cutting sheet metal, grinding
- Great for removing lug nuts and rotating tires, repairing engines and exhaust systems, sharpening blades, sanding wood, inflating car tires, cleaning workbench area, installing trim
- Longer life pump - durable and reliable cast iron, twin cylinder oil- lubricated pump designed for up to 5000 hours
- High quality, easy -to-read gauges
- Durable 60 gallon ASME code tank for safe, reliable operation
- Powerful 230 volt, 3.7 (running) HP motor (per ISO1217 standards)
- 155 Max PSI, 11.5 SCFM @ 90 PSI
- Three year limited warranty
