Need help w/ garage cabinet layout....
atwnsw
Hi everybody,
I am looking to order garage cabinets and can't figure out a layout that works.
Background: garage measures 279" total width. 2 windows. Each measure 36" Width. Trim around windows is 2.5". Height measures 37.5".
I will be ripping out all of the OSB including the workspace on the back left corner and replacing it with bead board (wood paneling). I will be relocating
the fridge to the right side so it won't impact any cabinets in the back. Height from top of window above 2.5" trim to ceiling is 10.5". Height from Floor to bottom of 2.5" windows is 42". Total Height of ceiling is 97.5".
From left 63.5" to 2.5" Window Trim to 36" Wide Window to 2.5" Window Trim to 69.5" space in middle to 2.5" Window Trim to 36" Wide Window to 2.5" Window Trim to 63.5" to right wall. Total Width is 279
From Top to bottom: 10.5" to 2.5" Window Trim to 37.5" Window to 2.5" Window Trim to 42" Floor. Total Height is 97.5
  • I am flexible on the brand. Newage or Gladiator or ????.
  • Budget roughly $5-6k max.
  • At least 1 workbench required. Possibly 2 max.
I looked at the Pro Series Newage 3.0 14 Piece set but can't figure out how to make it work with the back windows. Will be installing Rubbermade Fasttrack system on the left/right walls of the garage for power tools (chain saw, weed eater, vacuum, etc...)
Any ideas on designs is appreciated in advance.
The drawing is missing the 2.5" Trim around windows and off by 1" on the walls....
Thanks
screenshot-capture-2022-08-11-20-34-05-png.1711942
