dchasins
Last week I bought an Atlas 9360 bandsaw at an estate auction. The guy whose stuff was being sold seemed like he was pretty creative. He sure had a lot of tools and stuff to be sold off. Anyway, he had rigged this device between the motor and the drive pulley on the bandsaw. He had an actuator from a casement window attached to the lever on the end of the device. It was a funky setup, and the window crank was pretty well bound up. But I tried it, and it appears to be some kind of a brake, to further slow down the speed. When the lever is pulled toward the drum, it pushes a shaft in the end of the drum and slows down the speed by creating a load on the drive. The two pulleys on the other end of the drum are not connected one-to-one, but are somehow geared or slipped... It also looks like it has a fill plug. I haven't opened it up yet to see what kind of fluid--if any--is inside.
I haven't come across one of these before. For all I know, they're commonly used somewhere. Here are some photos:
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Thorsen%20wrench/Speed%20reducer/IMGP0187.jpg.html]
[/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Thorsen%20wrench/Speed%20reducer/IMGP0188.jpg.html]
[/URL]
[URL=http://s1212.photobucket.com/user/DMSKAuto/media/Thorsen%20wrench/Speed%20reducer/IMGP0189.jpg.html]
[/URL]
For now, I've mounted the motor conventionally to the saw.
So, ok all you experts out there...what is this thing? What was it originally used for and how does it actually work? Good thing to use in this application, if I can set it up with a better device to actuate the lever? Or a bad idea to put the extra load on the motor (1/4 hp Westinghouse, 1725 rpm)?
I'm guessing he put this on as a speed control for the saw. Wouldn't there be a better way, like a stepped pulley, or...?
Appreciate any info and thoughts!
[/URL][URL=http://s1212.photobucket.com/user/DMSKAuto/media/Thorsen%20wrench/Speed%20reducer/IMGP0188.jpg.html]
[/URL][URL=http://s1212.photobucket.com/user/DMSKAuto/media/Thorsen%20wrench/Speed%20reducer/IMGP0189.jpg.html]
[/URL]For now, I've mounted the motor conventionally to the saw.
