Need help wiring 5HP pressure washer
strutaeng
Dallas, TX
Hello guys, I'm thinking of wiring a homemade pressure washer I built several years ago.
I had a Baldor L3708T laying around and decided to make a pressure washer with a CAT pump I bought for it. The specs on the motor are:
5HP
23A
I've got a CuttlerHammer GFCI breaker (I think it was intended for a hot tub or spa) as a "switch" mounted on the unit.
I don't have a magnetic starter, but have thought about adding one. Would I just hardwire the magnetic starter with a simple 120/240V switch? Do I even need the GFCI breaker?
Northern Tool has 2 different 5HP P.W. One says it must be hardwired the other has a plug. 6-30P?
https://m.northerntool.com/shop/tools/product_200324563_200324563
https://m.northerntool.com/shop/tools/product_200347872_200347872
I thought the "corrent" way of wiring 5HP motors is to hardwire them per reading posts. I've been using an extension chord plugged into my NEMA 6-50R that I use for my welder.
Bert_
NW Iowa
I have never hard wired one. They come with wheels so is meant to be portable. I'll probably get hassled for it but I'd run it on a 50A plug without a second thought.
strutaeng
Dallas, TX
Bert_
NW Iowa
Manual motor starter would be the nicest. If the motor has a reset on the side you could get by with a 5hp rated switch or disconnect.
mm08822
The motor does not have internal overload protection. You must provide it either via motor starter or a manual starter (switch) that includes provisions for overload.
Bert_
NW Iowa
Judging by the part number the above is correct. None of the motor rated switches linked in this thread so far have this capability. If you get a manual motor starter be sure it has overload protection. A very simple form of overload protection could also be a 25A time delay fuse (125% of FLA for motors with 1.15 service factor).
mm08822
