Hey Guys need some wiring help with a new ceiling fan.
The old fan had some processor in that would not allow for using one light switch for the ceiling fan and one for the light kit on the fan. So on our switch plate the switch on the right had to be on for both the light and the fan to work and we would use the fan remote to turn of the light at night to run the fan. The light switch on the left did nothing if you turned it on or off.
When I pulled the old fan down I had your basic wiring pattern:
Green-Ground
White-White
Red-Black
There was another black wire in the ceiling just capped by itself, which I assumed was from the other light switch.
When I installed the new fan I wired it this way:
Green-Ground
White-White
Black from fan-Red
Blue from fan-to the other previously capped black wire.
So now I have the same problem both the fan and the light are still working off only one light switch, but now its the left switch on the wall plate instead of the right one.
My long winded question is what do I need to do to have the right wall switch turn on the light and the left wall switch turn on the fan??
Green-Ground
White-White
Red-Black
Green-Ground
White-White
Black from fan-Red
