Vista
I'm thinking about getting a 230V welder (Hobart 190/Millermatic 180 class) and would like to put a dedicated 230V circuit with two plugs in my garage. One plug would be near my workbench (about 10 feet from the electrical supply panel on the outside corner of the garage); the other plug would be at the front corner of the garage near the overhead door opening about 30 feet from the same panel.
I've attached pictures of the outside electrical service panel The first shows the breaker panel setup, the second is a closer view of the breakers, the third shows the panel wiring. It appears that I have 125 amp service since that's how the main disconnect breaker is labeled. It looks like there are three sets of ganged 40 amp breakers supplying the cooktop, double ovens, and air conditioner. There's two ganged 30 amp breakers supplying the clothes dryer, and up at the top, two ganged 25 amp breakers supplying a "wall heater" which I don't have. The house was built about 30 years ago. I assume that all the ganged breakers are supplying 230 volts to their respective device, but with the exception of the dryer, I can't actually see the plugins.
Need some advice: What do I have? What can I do to add the new circuit? I'm sure I'll be advised to hire an Electrician, but I'd like to be armed with the right questions and good answers...
