Need help with a DIY Tapered Fluted Oak Column
wrenchguy
NW Indiana
I needing to reproduce 2 interior colonade tapered & fluted oak columns. They'll be stained and varnished about 8' long. Looking for good fyi videos or a reproduction manufacturer. TIA.
edit, A round one, not flat one.
The Cobbler
I guess you'd need a lather for starters.
I did a custom trim job probably 35 years ago ,I had duplicated 12" butternut base & door casing , sills etc in oak . The customer wanted a column duplicated from the front staircase for use in the back addition. they had a local carpenter duplicate it and it was bang on
macgyver37
Pittsburg, Kansas
Look for someone with a Legacy Ornamental Mill.
I know a guy in St Louis area with one that does this type of work but he is booked out for a Long time.
PCustoms
VT
I'll give the short version of my idea.
Plywood "L" brackets on each end to support centers, may need to add a center support at that length. A long sled to hold your router.
Chuck the square column between centers, run the router as a live tool to turn it down. The sled can be built to work the taper in.
From there you index the column and run a ball end to get the flutes.
W
wrenchguy
NW Indiana
Thanks for tips so far, I should have mentioned i got 3or4 machinery lathes to chose from. It was automatic for me to not mention it because I didn't think of not using 1 of them. They're actually my sons at his shop but I don't think he has ever turned wood. So for my own education i should ask about using a metal lathe to turn wood. These will be about 8" diameter at base.
shoot summ
Pretty involved process, starts with just the glue up for the column as a solid piece will be extremely heavy, glue up will be too. Essentially a segmented glue up for the blank, then a taper attachment on a (BIG)lathe of sorts to make it round. Then a special jig to cut the flutes.
Based on that effort, unless there is an unlimited budget for time and money, I would look for a company that could make them, which will still be extremely expensive for wood(IMO).
PCustoms
VT
The lathe can do an 8 foot column?
Or are you going to stack several short pieces?
W
wrenchguy
NW Indiana
Well I don't know what his smaller ones center numbers are... but his biggest is 40' with 36.5" to ways.
I don't know what PCs are.
W
wrenchguy
NW Indiana
PC,
You quoted this,
"I should have mentioned i got 3or4 machinery lathes to chose from. It was automatic for me to not mention it because I didn't think of not using 1 of them. They're actually my sons at his shop but I don't think he has ever turned wood. So for my own education i should ask about using a metal lathe to turn wood. These will be about 8" diameter at base."
I never mentioned, "will this work"? I knew he had 1 or more big enough. I never set anyone up.
BTW I think the big Leblond came from a paper mill in VT. When pictured the install was just completed and "BIGBOY" had never cut metal.
PCustoms
VT
PC,
You quoted this,
I was making a joke....
I was propose some alternative, small run ideas and then you posted that pic, total overkill but perfectly adequate to make these (assuming the tailstock moves into 8').
Sumboodie
AK
PC,
You quoted this,
Setup to do rollers and shafts. Grew up in a logging and paper area.
2oolhound
BC Canada
As far as using a metal lathe for wood - it works great! Like cutting butter. Just cover the bed or you'll get sawdust and shavings everywhere.
Pick the lathe with the best taper set up.
PS: I remember your post about that monster and how you built the floor in the shop to support it.
I like the idea above for using a router to do the flutes.
W
wrenchguy
NW Indiana
All my sons work in his shop.
Good column fluting jig vids on the tube, that'll be my job when post turned.
