Rata221
Need help with motor problem. I am not that knowledgeable about electrical or motors.
I purchased a used 1/3 HP 1725 (sleeve bearings) motor to use on a drill press restoration. The motor/drill runs fine at the three lower speeds even- under the load of drilling steel. The motor tachs at 1760 RPM. If I move the belt to the largest pulley on the motor – under no load- the motor will only rev up to 1100 RPM and you hear the centrifugal switch open.
If I remove the belt from the drill spindle pulley, the motor revs up to the 1760. I attempted to put a load on the motor, by pressing wood against the pulley, and it doesn’t bog down.
The start capacitor tested OK with ohm meter – but I replaced it anyway since it looked like it was starting to leak. I doubled checked the wiring per the diagram on the motor. I had put new bearings in the drill spindle on rebuild - it turns very smoothly – so I don’t believe that is the culprit.
Only thing that I can think of is that the centrifugal switch is opening to soon (the motor staring slower in the higher gear or Maybe being in the vertical position? Needs stronger springs? I know sleeve bearing are not the best to run vertically.
Does anyone have any ideas about what might cause this? Or what I might try to fix it?
Thanks. Jim
Thanks. Jim
