rodder98
I have a 5 hp unit that had a Furnas air compressor pressure switch installed on it. It shut the compressor off as designed, but then the pressure switch would leak air pressure down, from near where the 1/4" copper tubing attaches to the pressure control switch. The tank loses the pressure down to zero instead of holding pressure.
I thought the Furnas air compressor pressure switch was defective and replaced it with a Square D FHG12J52XCP pressure switch that is very similar. But, the new one also leaks the air down also when it shuts off.
Obviously, I am not understanding something, but I sure could use help knowing what causes the pressure switch to leak air down. What am I missing?
