jweier111
Hi all,
Been lurking on the forum for a while and decided I join up. This is my first post, so I goof something up or step out of line let me know.
I am working on restoring an old Craftsman/King Seeley 6 1/8" jointer (model 103.23900) and am having trouble locating replacement bearings. I have the tool in question up on Vintagemachinery.org http://vintagemachinery.org/photoindex/detail.aspx?id=17787.
I know there are a few vintage craftsman guys on the site and am wondering if anyone might be able to point me in the direction of replacements. The bearings I removed are marked NDH 3202F-16. Listed in the manual published here on VM as part number 18236. I know NDH was owned by GM about the time these were produced, and I've found some NOS 3202 bearings on ebay. I'm not sure if the "F-16" at the end means they are different from the plain 3202 or if there might be a modern equivalent cheaper than the NOS parts (they want nearly $30 each).
I'm not sure how accurate my caliper is but the measurements I got were outside edge is 11mm wide, over all bearing width is 35mm, center opening is 15.5mm. here's a picture as well:
Any help would be appreciated. Thanks in advance.
). My inside diameter measurement is slightly over 15mm but not quite 16mm. I measured the shaft as well with the same result. From what I'm seeing on Motion Industries and ebay the 6202 comes in both 15mm and 16mm inner diameter. So my plan right now is to order one of each of the cheapest ones off ebay to establish which of the two is going to fit at all or with the least amount of play before ordering higher quality bearings.
). Explains why it was between 15mm and 16mm.
). Luckily one of the bearings I pulled out of the jointer was "good enough" to get it back together for the time being to use the wire wheel
(been using my old shopsmith up until now). Here's a little closer look at the grinder:
