Need help with changing PVC section
ive
Canada
Hi everyone.
I’m looking to change a pvc section of pipe. It’s too short by a couple inches. What I need to do is change a section of pipe on a T fitting. It has gray colour adhesive.
I
ive
Canada
Hi everyone.
Picture.
I
ive
Canada
I should be more clear. I want to change one section of pipe. What’s the best way to do this?
BD1
north side
Depends on which piece. Cutting pipe and adding another tee might give you what you need. Then plug the center of tee.
Kaizen
New England
Cut and add another piece and two couplings. Very easy. Get pvc cleaner and glue
nadogail
Coronado, CA
Furnace exhaust
You might get away with cutting the pipe at an angle and using a coupling to join the two sections. The amount of out of square you cut the pipe will effectively lengthen by double. that is if you cut the pipe 1" out of square it will extend the pipe 2".
Because it is apparently the exhaust on a high efficiency furnace there will be no real pressure in the line.
I have used this trip to lengthen water lines to lawn sprinkler valves.
Oledalee
SC
The pipe looks too small from picture for furnace exhaust. As said earlier could be condensate line but why the T. What size pipe is it?
