I have a big millwukie roto hammer. It hits the rebar and just sounds like it's ratcheting? Maybe I have it set wrong?
At least I'm pretty certain it's rebar. It's hard to see and my magnet sticks to whatever it is.
If you hit rebar, just keep the gun rotating, but put less-than-usual down pressure on it, just enough to keep the hammering action going. It could be 5-60 seconds, but eventually you'll hear the sound change and see concrete dust coming up the flutes!
As a grunt that has installed thousands of concrete anchors during my career, some of the threads like this drive me nuts. However, if I can offer one more piece of advice, never use an impact gun of any type to tighten a wedge anchor, only use a hand wrench!
The strength of concrete is purely dependent on the water cement ratio in the mix design. The more cement the higher the strength of the concrete as long as there is enough water present in the mix to ensure the hydration reaction takes place.
The actual achieved strength is very dependent on proper curing.
I have used sikabond adhesive to anchor 5000lb fans use it with 3/4" allthread.
we did 2000lb pull tests without a single failure. you can buy the stuff at home depot, just watch the expiration date.
You said Doug was wrong and then posted useful information, however none of which supports your point.Doug,
Sorry even with your later quotations from the concrete societies/university you are wrong or at least not understanding what they are saying.
True, curing concrete is a chemical process, not dryingYou are not alone. Most think that concrete drys like paint.
It doesn't, it cures and hardens in a chemical process that requires water.
Yes, insufficient water and the chemical reaction can not happenNo water the process stops.
I guess this is true, but not in any useful or predictable way? I learned something here.The good thing is it can be restarted even years later just by soaking it down, and keeping it damp.
This is true as well isn't it?It can also use humidity from the air or ground moisture to continue curing if present.
Following advice like this can get people killed. I hope those fans aren't mounted overhead, either...
Adhesives don't necessarily all become truly solid, even if they are "strong." They can still creep and many are not appropriate for tension applications like overhead work or for the bolts on a lift. These manufacturers will have warnings against using the products like this.
Before using any epoxy anchor, one should definitely check with the lift manufacturer and make sure the system/adhesive is compatible and approved.
What's the aggregate, then? Chopped liver?
This is why I decided to use longer anchors deeper in the concrete. Going deeper is basically like starting a fresh hole and the lift was designed to use 3/4 anchors. The specs say 3.5 inches is minimum depth and I'm 6 to 6.5 now. So hopefully I dont die haha
My comments were more about epoxy/glue choice. There are products that will work but we can't just pick anything off the shelf and have it be safe.
There's lots of goodness in going deeper with the anchors. Did you get through the rebar?
I wouldn't, epoxy adheres to the serrated thread surface of a threaded rod.
Whereas you anchor is smooth where the epoxy would be attempting to bond.
