Can some body that knows a bit about air compressors tell me why this wouldn't be a screaming deal. I am trying to find a good used home shop compressor. Even if I had to reconfigure with single phase motors couldn't this be set up to give me at least 15 CFM at 125 PSI for sand blasting, or am barking up the wrong tree?
It looks like each pump individually would not get me there, but can I change this or would I be limited to the ACFM of the individual pumps.
This was a back up system in a school bldg held at 60 PSI in the tank and 19 PSI in the lines for HVAC.
$900 for everything including the filter dryer system.
Specifications Model ES-20
Horsepower 3 5
ACFM 10.4 at 125 psi 12.3 at 125 psi
Fly Wheel Diameter (O.D.) 10.6
Oil Capacity 1 3/4 pints
Bore Diameter 2.56 in
Stroke 1.89 in
Dimensions (H x W x D) 14.1 x 18.3 x 12.6 in
Approx. Weight 70 lbs
Please school me on what a guy might run into trying to change this into something that would work for me.
Thanks in advance
Horsepower 3 5
Stroke 1.89 in
Thanks in advance
