alkknight
I just built a 40x60 metal building that basically has 3- 20x40 bays. It has 12ft side walls and was insulated with 4" (standard is 3") insulation. I have made rooms in a the first bay (16x40) which consist of a 10x 40 workshop that opens into the other two bays with a cased opening (would fit a 6'0" door later). There are three more rooms (2- 6x10 and 1- 6x 16). That area is decked and finishes around 8ft to the decking. I have a 5 ton split heat pump with 20kw strips and I have suspended the AHU from the ceiling at about the center of the 40 ft wall and 3 feet from that wall. I would lile to run come out of the unit and split it into two branches. One would feed the 40 x 44 open area (hung from purlins at 10 feet off front of building) and the other to turn down and run along the 40ft wall on the decking to with takeoffs to supply the other rooms from the ceiling. My problem is that I have no idea what size ducts woul be required to acheive this. I would like to use spiral pipe for at least the open area if not for the entire system. I can make a schetch of this and post it if none of this makes sense. Please help me figure this out. Thanks!
