diebog
So I have some stairs going from garage to house (indoors) that I put those Malibu half brick stair lights in that used a 7wat T5 bulb. I wanted to change them to LED because they keep going out so easily and they take hardly any electricity to power. I chose to use THESE LED bulbs because they claim they work as replacements for Malibu lights and were a good deal.
I have 20 lights total on this 60 watt 12v AC Malibu transformer (ML60T) and these LED's flicker like a super fast strobe light. Almost like when a florescent light is going out. But when I put a regular 7w bulb back in, there is no flicker in that one blub. My guess is the alternating current is either back-feeding or something causing them to flicker.
Did some research and found others have similar issues but couldn't find a direct fix. Some suggested a Full Wave Bridge Rectifier, to turn the 12VAC into 12VDC but I have no idea what to source for my needs. One sugg was THIS ONE. But is that all I need to fix the flickering?
Note: I would also like a way to dim the LED's all at once. Like a dimmer switch that I could wire after the transformer. Wife says they are still to bright
Know I know a little bit about electronics, but no where near enough to design whats needed. I'm able to solder, test stuff, replace electronic parts, worked with SMT parts a little, but that's about it. If I was told what parts to buy and had a simple schematic, I could put it together.
So is there a module out there that would do exactly what I am trying to do? (eliminate flicker and add dimmer) If not, is there anyone here that could help me out with the parts and what not to build whats needed? I sure would appreciate it!
