Need help with lights for my new garage
Jamie V
Atco, NJ
I have been working like crazy on my pole barn and I'm about ready to start buying some lights.
Garage is 24' wide 40' deep with 10' ceilings. I just finished insulating, sheathing, and painting the inside (gloss white)
The garage will have all exposed conduit on the walls. I also plan to put a ceiling fan in the center of the garage where that temporary light is hung.
I'm not sure if I need 8' lights, 4' lights 2 bulb lights or 4 bulb lights. I don't know anything about fluorescent lights at all so I need a run down. I have read about needing around 100 lums pr sq/ft but that's it. I know I like it bright so that sounds good.
Also I've read not to buy lights at Home Depot so I need to know where to go.
Thanks
Jamie
pattenp
Virginia - USA
I suggest the 4 tube 8ft T8 fixtures, either from Lowe's or Home Depot.
Edit: 9 to 10 of those will give you around the 100 LU per sqft.
Steevo
43.49600, -112.04300
My shop is 24x40 with 12' ceilings.
I used 8' long 4-bulb T8 fixtures (from Lowes).
Mine are on three separate switches, and in 4 rows.
I used 12 fixtures for the overall coverage, in three rows of 4 fixtures long, plus two in a fourth "row" on the side of the room where my bathroom structure is.
I also have three additional 8' fixtures located above workbench areas.
J
Jamie V
Atco, NJ
Both of you guys suggest lights from lowes (or Home Depot) some guys say not to buy the lights from there????
Steevo
Define "better"?
If a modern electronic ballast is designed to operate in low temperatures, not emit RFI beyond legal specifications, and functions reliably, how do you make it "better"?
J
Jamie V
Atco, NJ
Define "better"?
Better internal parts? More energy efficient? Longer lasting? Less prone to premature failure?
I don't know that's why I'm asking. I'm a union sheet metal worker and I can tell you that getting ductwork from my shop vs Home Depot is like night and day. I just wasn't sure whether there was a difference.
pattenp
Virginia - USA
If you buy Lithonia or Metalux (Cooper) from Lowes or HD they are the same fixture at a electrical supply, just more expensive at the supply house. At least that's been my experience. Stay away from the Utilitech junk at Lowes.
FOWLER
Smithfield /Suffolk VA.
I used 12 4ft lithonia T5 HO fixtures in my 32x30 garage. I have 10ft ceilings and don't have the walls and floor finished yet and these things are insanely bright, I usually only have 8 of them lit at a time and probably could have got away with fewer fixtures honestly.
If i remember correctly im at 125 lumens per sq ft roughly. I purchased them at Home Depot
J
Jamie V
Atco, NJ
I have OCD (self diagnosed) and everything has to match. So I'd have to with match the ones I have or get all new ones.
Norcal
How do you like them? How many do you have? What kind of money are they?
Should I buy 8 more to go with my 8 or just buy different ones?
I bought mine from the Habitat for Humanity ReStore, they sold for what I would guess for less then a 3rd of cost, which I guess as about $100 each, they were overordered for a school job & the excess was donated. Kenall lighting products are expensive, & these had some options added too.
