jonindallas
- Joined
- Aug 27, 2025
- Messages
- 7
I have a shovel ( actually 500 of them ) that were manufactured with welder's slag rattling around inside the 1.25" pipe. We've since fixed that issue but I'm trying to figure out how to either remove that slag or immobilize it ( ie: squirt some kind of adhesive inside to get it to stick to ) instead of just junking these and losing my *** ( the slag doesn't affect the performance but the rattle is maddening. My problem is that it is completed sealed. The only thing I can think of besides drilling a hole on the outside of the shovel shaft is to try to go in through the t-handle. That would require some kind of tool to go in at a 90 degree angle and drill a hole, then squirt some adhesive and tilt the shovel to get the slag to stick to it. But, that pipe is 1.25" so it is quite a small area to work with. Attached is the area I am trying to access ( the pipe making up the handle is sealed so right now there is no access to the shaft ).
Any ideas would be greatly appreciated and thank you for taking the time to read this. - Jon
