Need help with passively cooling a Texas Garage
mightyhead
Hey everyone,
I have done a ton of research both on this site and other sites and before I threw more money at this issue I figured I would ask what y'all think.
I live in Austin, TX and in the summers (especially right now) it gets to the high 90's, low 100's with lots of wind and little moisture. My garage was generally as hot as it was outside. The attached garage came with uninsulated walls and door (except the wall that it shares with the house) and the attic is completely uninsulated. The attic has drilled soffits in the easements and one 9"x9" vent about 4 feet down the side of roof. I have no windows for a window unit (wouldn't that just solve most of my problems) and I really don't want to buy a free standing portable unit (cost mainly, maintenance, and regardless, i need to get the garage as cool as possible before i try to actively cool it so i am not paying a ton to run the conditioner). Cutting a hole in the wall for a window unit would lead me to divorce proceedings ... = P
My goal was to turn the garage not necessarily into another living area, but just cool it from its current 100 degree at 3pm self. I recently came into a nice front projector for free and i would like to be able to leave it in the garage as well as any AV equipment so I would be able to watch movies/play games in the garage on the 104" screen in the evenings. That means getting it to ~82 if possible ...
The first thing I tried was radiant barrier on the garage door. For some reason all it seemed to do was raise the temperature in the garage. In some ways this makes sense, as the garage is still basically a closed box with zero ventilation. I then thought "well, it must be the attic is just too hot, and i need to insulate the attic, add additional venting and put up some radiant barrier." So I buy the vent (just another passive 9"x9" that I would put higher up on the attic ceiling but on the other side) and necessary installation materials, and climb into the attic to find that it is actually quite nice in there, lots of ventilation coming from the soffits and out the top from the single vent (i have to admit, my wife was not too jazzed about me jigsawing a hole in the attic roof).
At this point, I am at a crossroads. One option I considered was to open up some vents inside the garage to let hot air rise into the attic, and get a ceiling fan for the garage, and add the additional vent for the attic (and worry about insulation/radiant barrier for the attic later). Problem is i have no idea if this would actually work. I opened the 2' x 3' opening to get into the attic and it seems to alleviate the temp slightly, but not much. It is a flat ceiling so hot air would have to somehow find that opening to rise up, and i imagine there are hot spots in the garage. I would hope that the ceiling fan would cycle the air around and the hot air would eventually find its way up the numerous vents i would add to the garage ceiling, but i have no real way of knowing this will work.
As much as I am for a passive, cheaper solution to my garage cooling project, i don't want to cut a bunch of vents into the garage ceiling just to have to get a portable unit that I would then vent the hot air into the attic to blow out the top through the vent(s). I don't mind the work, but i would like to keep costs down, and moving parts down (other than the necessary ceiling fan i plan on adding) as much as possible. After the radiant barrier did nothing for me I got a little gun shy about my project plan (i didnt expect anything drastic from the garage door radiant barrier, i just didnt expect temps to actually rise). It does look pretty cool though.
So that is my story, I apologize for its length, but I hope I covered everything ...
Thanks so much,
-dave
Jag Mama
Hi Dave,
I live in west Texas (where it can get up to 120 in the garage :mad:) and have been trading posts with a guy who may have just what you need. I think I am going to order one of his units for our garage. The thread is "Garage Cooling that Works", or something like that on this site. Let us know what you think.
Good Luck,
Jag
M
mightyhead
well i don't have an external door, so that really isn't an option. thanks for replying though. for those taking notes, i did install an additional vent in the attic this weekend, although it did not make much of a change so far. (it was 122 in the attic and 102 in the garage). Insulation and radiant barrier is next for the attic. hopefully i see a change in temps.
kbs2244
Two things.
Shade and ventilation
Plant some leafy trees on the south and west sides.
I like the wind turbine type ventilators since they don’t need any power.
You should have some low level input vents.
(Do not put them in the bottom of the garage door, right above that 200 degree blacktop though.)
ni[x]it
Fargo, ND
I live outside Dallas. My home is a regular ranch house, with the southwestern exposure being my garage. The temps outside yesterday were 96 degrees when I got home. I checked my attic temp and it was 105 degrees (@ about 10 feet off the ceiling joists), and my garage temp was 87 degrees.
I FIRMLY believe the radiant barrier in the attic played into this.
I also added insulation to my garage door in the form of the metalized backing foam board. (metal side facing in to the garage). This too was a HUGE benefit in preventing radiant heat from my aluminum garage door from effecting the air temps.
If I am working in my garage during the early to late evening when the sun starts to set, I only crack the garage door 12" for ventilation. (Or, I turn on my portable A/C unit with works "ok", but I havent used it yet this summer).
Sounds like you are heading in the right direction!
philbilly
I have a 30 by 40 insulated metal building in fortworth.
I insulated the garage door (faces west...ug) That made a huge difference.
I tried a big window unit I got cheap, not enough to do the job properly. Does make it tolerable. If its 105 inside, it will cool it to about 88.
Someday I'd like to get real ac out there.
For now I just sweat profusley then sit in front of the swamp cooler or point it where I am working.
It moves some air! If I take the side pannels off, the blower moves the unit if you don't lock its castors.
I highly recomend the swamp cooler just for its ability to move large volumes of air, ease of mobility.
Lowes has them..think I paid $375
I suppose you could find cheaper blowers.
P.S If its humid, your SOL
