Need help with tap and die set and rethreading set
muskaman67
Hey guys, I'm looking into purchasing either a tap and die set or a rethreading set. I need some help with knowing exactly what each is for or if they can be interchanged. I know the tap set is so if you make a hole u can put threads into it. But the rethreading set is for what? Just fixing threads that are damaged? All i basically need it for is fixing existing holes and threads if i come upon them. I'm a technician for Toyota so i don't know how much i will be using either the tap set or the rethreading set. And obviously it will have to be metric. What would you guys pick? Thanks.
muskaman67
Would a rethreading set be more useful for me in my case or should i get the tap set?
muskaman67
ok thank you. Any companies better then others? or is snap on my best bet?
scott37300
Wisconsin
Tap and die sets are for making new threads, you can use them for cleaning existing threads but they can "cut" a little to much and weaken the threads.
Rethreading sets are for cleaning and fixing existing threads, will not cut new threads.
MattT
I use regular taps and rethreading nuts. I use the cutting capability of taps but never need to cut male threads. I also have a set of tap sockets though. If you don't have or plan to buy those you'll find rethreading taps easier to use in tight spots.
Homoudont
Baton Rouge, LA
I have the craftsman rethreading set and it is indeed the same as snap-on. I only work on my own vehicles as a DIYer and use it to clean up threads when working on rusty nuts bolts.
scott37300
Wisconsin
The craftsman set is a 40 peice and the snap on set is 48 peices. Might be made by the same company but from what I saw they are different sets. And the craftsman one is 50 bucks and the kastar one that is the same as snap on is 53 bucks. I would go with the kastar one from tooltopia.
