Need high bay LED lighting MANO
intex
MANO: money almost no object , number one priority is quality and quantity of light, not so much the cost, within reason
I have two attached garages with a wall between the two
1. 2 car enclosed garage with 11 foot ceilings , and 2 single post car lifts
2. 1 car enclosed garage with 11 foot ceiling and 1 single post car lift
What I need is enough lighting in the 2 car garage to be able to do work inside and see everything, I'm talking older eyes. I would like it bright, and the lighting has to be LED and surface mounted on the ceiling.
Any ideas would be appreciated, as well as locations for the lights, as if they are placed directly above car, it will limit lighting when the top car is on the lift.
Thank you!!
cybrdyke
USA
You'll need to ask someone to do a lighting layout for you. They'll need the dimensions of the spaces including the height that you will mount the lights. They'll need to know your ceiling color and wall color and the material that they are made from will be helpful.
There's a few forum members here that can do it.
good luck
CD
