Erampu
Before you mix that resin, let me introduce you to my ex...
i did a black concrete countertop in the new house, its awesome, i'd do it again in a heartbeat!
I'd really be interested in more detail on your counter tops if you don't mind sharing....
Nice job, BTW!
my dads bar used old hardwood flooring, looks really nice
if you are into boats or ships I would use a teak wood top
bob
I like the items embedded in resin idea. I have a ton of old bottle caps that I always said I was going to lay out in a design and use for this. Some day...
Well for starters I would have used hardiboard or some 1/4 cement board as your base instead of plywood. The plywood will absorb the water from the concrete mix during the cure period which will weaken the crete. You can also warp the wood because of it soaking up the bleed water.sure, what do you want to know, i built the cupboards myself, then i formed the countertops with lumber, the top of each cabinet has a piece of 3/4" plywood screwed and glued on it, the plywood has a 45 degree bevel all the way around, the edges were reinforced with rebar, i also added expanded metal lathe . i bought black countertop concrete from some outfit in california that was not supposed to crack, it was ****, i did everything right and it was lumpy pouring, hard to work and they craked in several places, plus the finish turned out looking like ****, so i coated the entire thing with an industrial epoxy, at first i bought a food safe epoxy and it looked like **** as well and would scratch if you looked at it. so i went back and asked for the most toxic stuff they had, the stuff they sold me rocks, stunk like hell putting it on, once cured you can't beat it, and the sheen is a perfect satin black.
heres a pic of the forming...
I would be curious as to what brand you picked up. Not all bagged brands are created equally.
As far as the finish, it can take a seasoned veteran to finish a cast in place countertop. I have done a few and am still not great at it. I prefer precasting my pieces.
