I need help making some stuff more easily to be used on the bench but not on the work bench all the time. I bought 2.5" square tubing like what a truck hitch is made of. I also bought 2" square tubing to go in like a receiver. My problem lies in trying to weld the 2.5" square tubing to my bench. I have a 40"x12' work bench. I ran 2"x3" square tubing the length of the 12'. I have 2"x2" box tubing for cross bars. The 7/16 steel plate for the top sticks out about 4" in the front.
My problem is, what is the best way to weld the 2.5" x 2.5" to my work bench? Do I weld it to the 2'' x 2'' box tubing and cut 2.5" out of the 3''? My other choice was to weld the 2.5" to the bottom of the 2" x 3" box tubing. Lining the one side 2.5" x 2.5'' to the side of the 2" x 2" cross piece and then weld a couple 1/4", or 3/8" flat steel to the sides of each. The other side will have the same flat steel only be welded to the side of the 2" x 2" and to the top of the 2.5" x 2.5".
What idea's do you have? If it matters I will be using it for a woodward fab hand shear, eastwood bead roller, a vice, tubing notcher, and so on. I don't want these on the bench at all times. I already have one vise on the bench on one end.
