HemiRamOn22s
I'm looking for some input on what size air hose reels i should use in my new shop. I've already installed the M7500 3/4" Maxline kit w/ 3 Drops in my 40'x80' shop. The install went great. Im going to pick up a Quincy 80 gallon Vertical Air Compressor (17.7 CFM @ 90 PSI) controlled by a RapidAir 3/4" Filter/Regulator set at 90 PSI. I've done one drop in the rear of the shop by my compressor and work bench, one in the welding shop, and one by the garage doors in the front. I used exactly 100' of Maxline. The outlet size on the distribution blocks is 1/2" NPT.
Im torn between getting 1/2" Hose reels and 3/8" hose reels. Almost all of my air tools are 1/4" NPT and I plan on running high flow 1/4" V Style Air Fittings. But if i ever did pick up a 3/4" or a 1" impact is the 3/8" hose going to give me enougth air flow? Should I at least pick up one 1/2" hose reel and leave the rest 3/8"? All 3/8" or all 1/2" hose reels? What is everyone else running?
The hard part is finding a true 1/2" NPT whip hose to go from the D-box to the hose reel itsself. I would have to have something custom made. Im trying my best to have the maximum flow possible at all of my air tools. Here are a couple pictures of my Maxline install. The link to my build is in my signature.
Thanks in advance!
Thanks in advance!
