kf4zht
So after month of searching I finally found a metal lathe. Ended up getting for $165, which in this area is a steal. It needs a good cleaning, and only has the 3 jaw in the pics, but I can make up for that when you compare to the $2500 south bend bench models around here.
Hoping that someone has some info on this. What I know:
Model Number is 11059
Northern Hydraulics sticker on the back side
Mfg Date 10/1991
6 Amp (~1hp) motor
Appears to be around a 9" swing by ~20" long
Appears to be asian make
Anyone know anything like the manufacturer, or better a manual with parts diagram? The thing is covered in grease mixed with sawdust. Minimal rust, but the levers are all tight and need to be scrubbed.
Mfg Date 10/1991
6 Amp (~1hp) motor
