Can you ? YES, but you have to be VERY CAREFUL ! One wrong move and you will bend the **** out of the wheel !One last question: Can you use the old tire machines to mount Aluminum rims/tires?
- The rim rests on a steel base. You want something like a piece of carpet/heavy rubber there so you don't scratch it even it it is the back side.
- The center hold down is also steel. A rubber/plastic coated steel bar between the center hold down "nut" and the rim will take care of that.
- The top bead breaker is also steel. Again, rubber/plastic coating on the clamp part will prevent scratches.
- Careful placement of the top bead breaker pressure arm will keep it off of the rim.
- Most of those style tire machines break the bottom bead at the same time and you CAN NOT SEE what they are doing, so hidden damage CAN occur !
- The tire mount/demount tool is also steel and rides ON THE RIM ! As silly as the sounds, you can get a manual mount/demount bar that has plastic ends and that will solve this problem !
Last, those style of machines might not work for rims bigger than 18"
