Hello all, I just purchased the Kobalt 155psi 30gallon air compressor from Lowes about a week ago.
My air hose is Goodyear 3/8in 50ft with 1/4 fittings.
The problem im having is I cant seem to break loose my lug nuts that i put at 120ft pd, with my 700ft pd craftsmen impact wrench.
They have been on for awhile now close to a year.
I can take off newly torqued bolts but not the ones that's been on for a while.
After doing some research on this forum, will 3/8 nozzle fittings with the 1/4 npt threading give the cfm and the pressure needed to the impact wrench?
High flow fittings discussed here, are those the 3/8 fitting with the 1/4 threads?
Thank you
Thank you
