wolfestone
- Joined
- Jun 12, 2010
- Messages
- 7
I have a ~750 square foot single story 3 car garage which I am trying to light.
Right now, it has two screw-in bulb fittings (100w max) on the ceiling, two double outlets on the ceiling (garage door openers are plugged into one socket on each outlet). It also has two exterior lights (60w max) and all the power outlets on the same circuit, which as far as I can tell goes through a 15A breaker. The house is <10 years old.
Ideally I'd like some kind of bar lights which I can raise/lower on chains. It would be great to have them switched at the wall but I can definitely make do with having pull cords/inline switches on the cable.
I spent some time in Lowes and saw they had one which seemed brighter than the rest: utilitech light but I still can't figure out if this is a regular flourescent light with confusing marketing, or an actual LED system.
I'd really appreciate any suggestions on what type of lighting (flourescent/LED), how many additional lights my system can probably handle, and anything else e.g. one four bulb light vs. two two bulb lights. Ideally I'd like to budget for around $50 per light or less, but I can go a little higher if it would make a difference.
Thank you for any help.
