Shrouded (sheathed) are nice, but not mandatory. Even meter designed to use them will work with standard banana plugs.You'll need shrouded banana jacks.
True. But I can't think of a reason to go with bare banana plugs anymore, unless you're dealing with older jacks that cannot work with shrouded plugs.Shrouded (sheathed) are nice, but not mandatory. Even meter designed to use them will work with standard banana plugs.
I am installing quick connectors to attach a BatteryMINDER ( rotated from battery to battery every few weeks because I would need 10 batteryMINDERs to do everything24,7,365) and would like to sometimes check the batter voltage with a free HF multimeter I got by just plugging it in.
HF uses different leads then most.
2 things, first Yuasa makes a 10 bank charger if you actually did want something like that (just sayin').
http://www.motoparthub.com/YUA12002...lOyLrSCJvPtNvsO15-bG3NPghHH5b9XENShoCKgvw_wcB
Second, I would respectfully submit that you're looking to spend more on the leads than the meter they plug into. Plus, HF meters take unusual plugs so you may have to dig around to find them. Why not drop a few bucks on even just a basic meter with normal banana jacks and make your life a little easier? Just my $.02, nothing more.
Considering the application and cost of the meter; Why not just cut off the probes on the existing leads, and attach clips, or whatever ends you want?
Fair enough! Small word of warning - use your good meter to verify the HF one is accurate. You might be surprised how many people I help troubleshoot motorcycle problems over the 'net only to discover their HF meter is reading off by ~3 volts.I have a good Snap-On multimeter. The reason I want to use the free HF ones are that I may leave it around and if it gets broken, I can just get another one off my shelf.
I did this recently. The wire gauge they use is pathetic, so I have no illusions of it lasting very long.
Factory made leads typically use 18 gauge wire, but I would use 16. Cheap ones may be 20 gauge.
The local electronics store I often visit carries test lead wire and calls it as such.
Being it has been -20 the past month or so, having that wire makes a huge difference.
Factory made leads use silicon insulated, high wire count (fine) stranded copper wire. This is also the same wire that radio controlled cars, trucks and airplanes used and is available for reasonable price from many vendors on eBay.
