Need new wire strippers crimpers
Shane8820
Looking at Snap On PWCS9CF and PWCS7CF specifically. Wanting to know which one of the 2 are better and why?
IMG_6050.JPGf1349edb55ea20547e599c7769f62173.jpg1a19f6925639e7fcb5ba429d0016e67c.jpg32ff4ba56be782d62980892306e54f28.jpg
Roobaix
White Plains, NY
I also have the 2nd pair and like them plenty fine, but I also use other strippers that look very much like the 1st pair.
I'd say I use the 1st pair more often as they are more geared towards an electrician IMO. 6x32 and 8x32 shear (common wall plate screw sizes), strippers in the front for easier access, and a gripping tip.
Shane8820
I suppose I should mention that these will be general purpose. I'm a diyer. I'm an aircraft mechanic by trade but I also work on everything from air compressors to wiring up garages.
jumbojak
Surry, VA
I have a Carlyle clone of the second pair. They work great until you need to strip a wire that's very short and recessed. I recently replaced a headlight socket on a 2006 Trailblazer and really wished I'd had a pair with the strippers on the nose of the pliers. Of course, if I had a pair like that I'd have been wishing for a pair with the crimpers on the nose! Either would work fine until you found yourself in a situation where the other would work better. Personally, I'm looking to get a dedicated pair of strippers for situations like that. Having a combo tool is great because there's one fewer tool to lose. They don't always fit though.
shockwave
Marietta,ga
I own both and the smaller of the 2 the s7 #2 on your pictures I prefer as my go to perfect for crimpers and strippers most of the time
The others are a bit bigger and harder to use in tight spots but will offer easier stripping due to design of pliers
And also otc makes a cloned version of #2 aswell as a 90 degree crimper version that are pretty cheap aswell
Bobioz1
Northern il. (For now)
I own both and prefer the smaller one. The smaller one also comes in two different size wire strippers. Automotive wiring keeps getting smaller so make sure you get the right size. Or just get both.
thegroundpounder99
Balm Fl
I have both, the 7CF looks like it has gone through a war while the 9CF is brand new cause it hasn't moved. The 7CF's are the best crimpers IMO.
Brownsfan
Cleveland Ohio
If it's only between those 2 then the 7" one. I have them and really like them for tight spots or when I'm in a position where one tool for 2 jobs is needed. That said . In all other circumstances I usually prefer a separate stripper and crimper. Something like this to strip existing wire back so you can tap into it https://www.walmart.com/ip/21192830...75035&wl11=online&wl12=21192830&wl13=&veh=sem
These to strip wire ends.
https://m.sears.com/s-g-tool-aid-19...gclid=CKDoicSNk9ECFY-4wAod4S4Gdw&gclsrc=aw.ds
Then these or similar to crimp.
https://m.lowes.com/pd/IDEAL-9-3-4-in-Multi-Tool/999960629
NFH2740
NE Indiana
I have the PWCS7CF. They are my favorite electrical pliers to date.
I wish I bought the PWCS9CF as I use 10 gauge with some frequency (Agriculture). I improvise with the wire cutting edge.
Biomed
Minnesota
There is a PWCSS7 and a PWCS7. They are very similar. The PWCSS7 will strip AWG 14-24. Not sure if the PWCS7 is discontinued.
The PWCS9CF will strip AWG 8 - 16 (solid) and AWG 10 - 20 (stranded).
Anyone know what the shiny button is for on the PWCS9CF (left photo)?
kball
SoCal
Lock them closed and it doesn't work well. Just jarring around in my cart drawer they open up.
Brownsfan
Cleveland Ohio
They look similar. Those Neikos are the same as the OTC pair I have. I also have the Snap Ons. There is no comparison. The Snap on set is much more substantial feeling. The grips are way more comfortable. It's not even close.
pstemari
Seattle
Greenlee/Paladin PA8000 with appropriate dies for the crimper, Klein Katapult for the stripper on larger gauges, one of the automatic single hand strippers such as OTC 4466 or 4467 for smaller gauges (18 and under).
Sent from my Nexus 6 using Tapatalk
