johnnyturbo
Just curious if someone can advise me on how much is would cost to build a 30 x 40 pole barn as described below.
14' ceiling with full load bearing 2nd floor accessed by steps at rear of barn.
2 9 x 12 insulated garage doors
1 6 panel man door.
5 32 x 48 vinyl windows on ground level
2 23 x 48 vinyl windows on end walls on 2nd floor
concrete floor 4" on left side, 6" on right side (for a lift)
wired w/GFI to code 100 amp service 220 volts
interior paneled with OSB plywood - not sure if insulated.
I have a good change of purchasing such a building that sits on .78 acre in Ohio (where I live) and I obviously do not want to over offer/bid on the place. It's 17 years old, but you can't tell it by looking at it.
Also curious as to how one one would arrive at a "used" value for an older pole barn. When it came time to refinance my home, the appraiser valued my pole barn (same as above but with 8' ceiling) at $9000 and it cost $35,000 when built.
What I don't want to do is offer $40K because it would cost $65K to build and then find out it is really only worth $20K.
1 6 panel man door.
