Need opinions: Husqvarna vs. Hustler
espyking83
Hell hole of a King Air 200
Replacing our mower this year and think I can get good feedback here. I think the 42" Hustler seems to be better built, but the Husq is $400 cheaper and my wife wont let me forget it. The Husq also has a B&S engine, and from what I hear they have cooling issues. Thoughts?
outlawz2004
I have a Husqvarna 42" cut zero turn. The first two years it ran great. Third year had a bent valve. This year I'm replacing carb and fuel pump. Cheaper to replace the carb then to rebuild it. Its been a decent mower, but plan on getting a new one after this year.
cgrutt
Are you looking at traditional riding mowers or zero turn? I bought a Ferris 62" walk behind (which is essentially the same as a zero turn but you don't sit on it) and it was great. It's a commercial mower though and on expensive side. They make them smaller and in zero turn. You should definitely check them out if you have a dealer nearby. Not sure what your budget is though.
Had to sell mine. If I had to buy again I'd probably go for a zero turn.
Hydrostatic transmission is great to have in a mower. As far as engines go I think Kawasaki makes about the best but obviously more expensive. Briggs and Honda make decent engines too.
Good luck!
gdocktor3
Connecticut
Hustler is more of a commercial mower company, while Husqvarna mowers are more home owner based. Even the Hustler residential mowers seem much better built. Myself, my father and most of my friends/family all prefer to buy commercial grade stuff over residential/home owner stuff. I have a commercial grade, 2005 Toro Proline 52" with 16hp Kawaski motor I bought in 2007. Same motor as in Scags. It now has about 300+ hours and I've only replaced the blades and one belt. My uncle bought a brand new Husqvarna ride on tractor 2 years ago that's been broke down in some way no less than 5 times. Hydraulic pump once and something with hydrostatic transmission. Granted its not a zero turn, its still a Husqvarna and you'd think would be better built. I also bought a Honda push mower last spring. My other option was Husqvarna. The dealer told me straight up the Husqvarna decks aren't as thick or strong, and it had a Honda motor...
Keep in mind, Husqvarna, Honda, etc sold in Lowe's and Home Depot are not the same as those sold by your small mom and pop lawn mower shops.
firebox40dash5
Hustler is more of a commercial mower company, while Husqvarna mowers are more home owner based... its still a Husqvarna and you'd think would be better built.
Although Hustler builds cheap mowers too, and Husq makes a few that are supposedly commercial grade... so there's that. I'd definitely favor a residential Hustler over a cheapo Husqvarna though.
As to it "still being a Husqvarna," it's really not. I'm not sure about their "commercial" ones, but in the cheaper ones the only Swedish thing about them is the name. Same AYP garbage as everything else cheap, with different stickers... like a HF box with Snap On badges. :lol:
jkwilson
SW Indiana
I had a Dixon that was a decent mower, but when Husqvarna bought them the price for parts quadrupled. Left me with a bad impression of the company.
Xxslyer1
I've been using Husqvarna commercial mowers for 10 years, 2 years ago we replaced them with the new mz6128 before they cheapened up with smaller 3100's and a few other changes. They came with the fuel injected b&s motors and my fuel cost was literally over 1/4 nearing 1/2 cheaper since going that route, one mower has 1600+ hours and I've replaced Kawasaki motors at 800hrs in the past. Hustlermoffersnthe flex forks and air ride seats but IMO with flex forks attached you don't get the greatest quality of cut because the deck isn't level when the forks DO flex. They both make amazing mowers.
Xxslyer1
Been using a Hustler 60" I bought used 8 years ago with very little issues.
It has a Kawasaki engine and with proper maintenance I wouldn't change a thing on it.
As much as I love the kaw motors tq the fuel it drinks absolutely kills me. That and alot of mowers are 1500 more just because of that motor.
For 1500 I can replace it with a Briggs 3x. I used to exclusively use kaw motors though.
SweetD
Rhode Island
My brother has a part time summer landscaping business in NC. He has two Hustler zero turns and swears by them. Very few problems.
Busted_Knuckles
Northwest Illinois
This thread is an apple/orange/pear comparison.
Way too many engines, and build levels to compare " hustler to Husky ".
Specifics, I mean, Husky is building 3 different tiers of ZTR, I dont know Hustlers tier levels, but Im thinking its more than one.
You can compare a Huslter and a Husky, but it needs to be model to model, engine to engine.
Then you have different levels of the engines, including briggs offering different levels of quality and price, etc ( endurance vs. vanguard )
Anyway, not sure how you are comparing machines, with zero specifics, and the hardware changes from machine to machine are drastic ( deck gauge-stamp or fab/drives/engines/etc )
So to provide an opinion, I think at least two competing model numbers need to be shared along with engine spec to offer up meaningful input..
BTW, " LawnSite " is where you might find the the depth of knowledge to be a wee bit deeper. Im not a member, but every specific search leads me there.
Bdgjr215
Cant add anything to that I agree totally.:thumbup:
CNGsaves
KS and OK
+1 to analyze until you get to Apples vs Apples.
With lawn mowing crews I've seen. many do have Hustlers. Also, those Hustlers made in Hesston, KS by Excel Industries which is great company. I'd vote Hustler.
rustbucket5
i work as a mechanic for a landscaping company, and i can tell you right now, get something commercial grade and properly maintain it. we use toro stuff and its really well built and reliable but expensive and some can be quite complex to work on. my sister has a small landscaping business and she started with toro homeowner stuff and it lasted one season. homeowner stuff just isnt built well at all, most dont have fuel or oil filters which right there is telling.
mikegt4
sw ohio
All too true, real commercial equipment will last a long time. My Walker MC is starting it's 15th season. Maintenance to date: 1 throttle cable, 3 starter solenoids (no problems after I moved it off the engine years ago) and it is now in need of it's 3rd battery. Still has the original blades (high grade metal), spindles/bearings and tires.
Just because a lawn mowing business uses a certain brand doesn't necessarily mean that it is "commercial grade". Lots of small mowing businesses buy cheap homeowner grade equipment and replace it very year as part of their business model. Look at what the larger landscaping businesses use.
chipss36
texas
:dunno:and I was thinking motorcycle or ****.....man tuff call...
and you guys are talking lawn mowers
Busted_Knuckles
Northwest Illinois
what about exmark mowers? I see a lot of big landscape companies using those.
The list of commercial machines, is long... and you can say that you see any one of them " out there "..
Ive noticed in my travels, allot of guys that get into mowing for a living, buy machines for several reasons, other than " what machine is the best for the money ". Like price point only, service only, credit given here only, etc..
For instance, some guys do not own a TOOL, and pay the dealer to do EVERYTHING. All brands are not sold everywhere, so if you have an Exmark dealer, with a " decent " service department, and no one else in the area carrying commercial machines, chances are you will a disproportionate number of Exmark machines. Is that logistics or demographics ?
You can make positive statements of just about any brand of commercial machines. They are all pretty good, if you get to the top of the line.
As MikeGT4 pointed out, hes on his 15th season.
I mow commercial properties with a full blown commercial John Deere ZTR that was new in 2001. No ZTR dealers around me, Im in farmland, but there is a deere dealer, down the road. See what I mean ? As the years have passed, more dealers have popped up, but back when I bought that thing, would have at least a 50 mile one way trip to buy parts for another brand.
While most would have traded it off, Ive kept running it, its built like a tank. Its on its third Kohler, the hour guage quit, back in...I dont know, 2008 ? I have no idea how many hours are on it.
Solid machine, motor drives, " 7 Iron deck ", just keep wearing out the engines, but for what it costs to replace that machine with a comparable machine ( any brand ), well, Ive kept shoving motors at it. I probably need a diesel, but dont want to spend the $. The machine I want is about $15k+, the machine I run owes me nothing, so I dont really care to go to work for a machine. My truck is a piece **** too, so is my trailer, but I actually turn a profit, most likely because everything is paid for.
One other note, on my statment that guys will buy what is sold serviced locally to them, just for those reasons...
Being that I live on a farm, and Im miles from any conventional housing ( like town ), all my neighbors farm. All the tractors around here are Red or Green.
The local Case Dealer ( red for those that dont know ), lost its franchise about 4 years ago. Now I have neighbors that have bought nothing but red, going back into the early 60s. Most of them still have that old iron hiding in a shed.
So the case franchise goes away, they pick up the Versatile brand, and like rats following the pied piper, next thing you know, EVERY new tractor in the "hood" is a Versatile. Point being, the farmer will turn his allegiance from one brand of 50 years to another, overnight and in mass, because the local tractor dealer, changed brands. Where talking $75-$250k purchases, not $1-$5K purchases. Anyhow I find that interesting.
I wont be buying a Versatile, I will drive the extra miles to the next closest Case dealer, but too each their own.
venturesomerite
Connecticut - not sure why though...
This is just like the thread I had a while ago "Craftsman vs *******"...
sorry, I couldn't resist.
I've had a few mowers in the past, currently run a walk behind belt drive ransomes bobcat 48". The thing never needs anything but gas. I use it commercially, but cut my own lawn with it too.
I worked for someone 10 years ago that ran all scag. The older 3 wheeled riders and walk behinds. Those were good machines as well, as long as you disable the foot safety, can't tell you home many times that switch screwed up.
I've used others, but in my personal experience, anything with a Kawasaki or older briggs just runs.
mitusa
SW Oklahoma
I have an older Hustler Fastrak. 54 inch deck with a 20 horse Honda motor. I've had no problems with it. Change the oil and put in gas. And it is easy to work on....I had to replace the belt that runs the ground speed last year, out in the yard, took about 15 minutes. I had to find my replacement belt and the owners manual.:headscrat
http://www.hustlerturf.com/products/Fastrak
HTHs
outlawz2004
I ended up replacing my Husqvarna with a much larger Kubota. I was going to go with a big dog, but its a lot easier to get Kubota parts in necessary. The Kubota controls are so much smoother than the Husqvarna, and everything is placed where you can reach it easier.
