Need Pipe Unions that don't leak
J Persons
Louisiana
I had to revise my air handling piping due to my new compressor. I installed two 3/4" pipe unions, sealed the threads using Rector Seal. Waited a couple of days for the electrician to hook up the compressor, turned it on and both unions leak like sieves. The threaded connections don't leak just the union connection. I have tightened them as tight as they will go. I have the regulator set to 150 PSI. Anyone know of a quality 3/4" pipe union that doesn't leak?
matt_i
Ward Manufacturing is where I would go. Typically available at McMaster Carr if local sources don't pan out. All of their fittings I've found accurately machined and easy to use.
The anti seize that Claas mentioned is a good idea to get more torque on the union-nut. Also a set of longer handle pipe wrenches will assist. When I'm sweatin' the black pipe fittings are usually tight enough. :D
J
J Persons
Louisiana
They are iron pipe fittings, I used Rector seal on the threads, the threaded part doesn't leak. I then tried a smear of Rector seal on the mating surfaces, waited about an hour, turned on the air and they leaked at the center of the coupling I got these at tptools.com I've never had a problem using fittings from TP Tools until now.
Chuckles
Don't buy the big box store chinese unions, buy the ones at the plumbing supply house or online, the ones made in America
Shiftless
East Bay SFO
That’s my experience as well. The Chinese ones from HD leaked (water) and the USA made ones I bought at my local ACE didn’t.
Buy some valve lapping compound and "lap" the male and female surfaces. Use Rector seal on the back side of the male and female halves and on the joining nut.
bczygan
DETROIT! Arsenal of Scrappers
NEVER use anything on the mating surfaces.
Bill
95vette
Hello, Cheap unions will drive you crazy, always install unions with the pressure coming thru the collar side.
RMS52
Verify the alignment of the two fittings. The two ends should touch either other and there should be no angular or side to side offset. The collar is not made to align the union ends; just to put pressure on the matching end surfaces.
skippydoo
Sussex NJ
We only use Ward pipe fittings at work. We got burned after we had to go back to aprox 40 gas stations and redo the piping under the pumps. We now only use fittings made in the USA
LifeLongWNYer
South of Rochester, NY
I second the motion about using USA manufactured fittings. While the Chinese stuff was junk, today my Home Depot only stocks sh** made in India. That makes the Chinese junk look stellar.
My local "home town" hardware sells American made fittings, I always buy there.
Jlarson
I try and use domestic made, brass seat unions on air service when we're doing new pipe.
But if I have to take something apart on a service call or equipment it supplied with a cheap union and won't seal back up you bet I'll touch up the faces and goop em up if need be. I've even had to put leakloc on less then stellar quality stainless unions before.
rharman
SoCal
^^ This ^^ Out of alignment just a bit and you're screwed.
I would think that lapping them or even the buffing that SBerry mentioned would be a huge help as well.
Personally, I would avoid unions at any cost. Especially for air.
Mr onetwo
Coastal Maine
dr_clyde
Holland, MI
Local plumbing supply house always sent me Anvil fittings, never had any leaky unions from them.
Beginning to sound like a general consensus to buy quality fittings from somewhere other than a big box store.
Tape and dope on the NPT threads, nothing on the mating seal between the halves.
rayra
Escaped from Los Angeles
you were probably being sarcastic with the suggestion, but with most air tools limited to ~100psi and compressors to ~150, and most smaller sched40 PVC pipe having a burst rating of 400psi AND being available in CPVC or even the simple expedient of UV protection via painting the pipe, I wonder why more folks don't use PVC. Helluva lot easier to work with and seal.
But the lore-howling against it is legend. And I can't seem to find much of a real basis for it.
eta just got a notification today, 220207, 32 months after this post, that rlitman gave me an angry face. Ridiculous.
speed bump
Butte Montana
PVC isn't oil resistant, its working strength varies with temperature, and it doesn't take shock and impact well. Not to mention when metal pipe goes it tends to open on the seam versus PVC that has a higher chance of exploding.
Monza Harry
Windsor ON
I have seen the pipe with a Black Blister on it's side hissing away. Oil and plastics (some, many) just aren't friends, bad idea with all of the first hand account here and every other similar (Ok ish +/-) forums telling of the same tales. Have you ever been in an industrial building with PVC Air lines? I have been in 100+ buildings and only one had plastic plumbing and I mentioned that one above, BAD IDEA Period. Just my experience, do what you will with it! Harry
The Cobbler
seems that unions are real bad these days.
when I did plumbing in school they always referred to as ground joint unions, you weren't supposed to mix the halves and we were always taught to put some dope on the mating surface .
if the pipes are out of line,and rigid, the union wont necessarily seal .
too bad so much stuff is on a downward spiral, even with modern machining etc.
kbs2244
Is there such a thing a gas rated unions?
Water unions are made to seal water, a liquid, at less that 100 PSI
You are asking them to work on air, a gas, at 150 PSI
That is way outside the design limits.
I would say you should buy the right product.
Rock knocker
They are WOG
95vette
Please do explain why?
Hello, If you will look inside a union the collar side has a tapered side that fits into the other side which looks like a funnel, therefore pressure flows thru easier than if the other way around. I have installed thousands of pipe fittings of every size from one quarter inch to forty eight inch pipe in my forty seven years as an industrial pipefitter, trust me it makes a difference.
Mr onetwo
Coastal Maine
I'd like to see that 48" union:bounce:
matt_i
How about so the collar doesn't drop down 11 floors when you loosen it, iow keep the collar on the top side if applicable :)
LS6 Tommy
Northern NJ
Folks do use it, but that's only because they don't understand the burst rating is for liquids, not gases. Compressed gases store energy and will have an explosive failure, where liquids don't. That's why using PVC or CPVC for compressed gases is a no go. It's 100% illegal because it's not rated or safe for any compressed gas use, regardless of burst rating.
Tommy
when I did plumbing in school they always referred to as ground joint unions, you weren't supposed to mix the halves ...
So how often is the tooling inspected/changed in plumbing fitting factories in India/China/Korea/Philippines ?
Hence my comment. Lapping compound and lap by hand !
