Last year we built a new 60x60 shop to move our motorcycle paint and repair business into. After hearing about the benefits of Radiant Heat, we decided to go that route, and installed 3 zones; One zone for our display and office area. One for the paint booth, and the last one for the largest area of the building.
Each loop is as close to 300ft as we could make them, and if I remember right, we didn't cut off more than 15ft of any of the loops at the end. Zone 1 has 4 loops. Zone 2 has 3, and the large Zone has 7.
We hired a local plumber who was 'experienced' as a paid advisor and to build our manifolds and as a purchasing agent. He advised us that Bubble-Foil-Bubbble insulation under the slab (1.5" thick) was the industry standard for insulating the slab. This was last October. I have been reading since then that this setup has nearly no insulation properties at all. Argh... We have a 6" thick slab on top of the "insulation". 1/2" PEX throughout with the first perimeter loops spaced 6" apart, all interior loops 12" apart, minimal overlapping, mostly just where the surface exit is.
We do not have Gas or Propane service at the shop site, so we attempted (at our advisors dismay... should have actually listened on this point) to use two, 80gal 9kw (dual 4.5kw element) electric hot water heaters. 20.7GPH recovery rate at 90F.
Each of our Zones are built with a Taco Pump on the input from a main hot manifold feeding an input distributive manifold into the PEX where it goes into the floor. An output distributive manifold is connected to the PEX exits and feeds through a 1-way valve into a mixing valve in case we wanted to feed some of the cold return water back into the input of the Taco Pump.. these mixing valves were always closed.
From there, the return water feeds through another 1-way valve into the main return (cold) manifold and into the input of the first hot water heater at the bottom. The output of that hot water heater feeds into the top input of the 2nd hot water heater. Output of the 2nd goes into an air bleed then back into the main input manifold for each of the three zones.
The Shop is a 60x60 with 10ft ceilings. We had 6" of spray-in-foam insulation put in the walls (R30-ish), and blow-in insulation in Ceiling (R35/40-ish also). The shop has one 9'wide garage door (insulated) and one walk-in door. It has two 8' wide display windows that are in the South-Eastern corner in the Display Room zone.
After running the electric hot water heaters last winter 24/7 and having $500+/mo electric bills, we never (NEVER!!) changed the temperature of the floor any further than 2ft from where the PEX enters the floor. The Hot Water Heaters are one problem (too low GPM recovery rate), and possibly the Taco Pumps are either pumping too much or too little. I dont have the part numbers for the Taco Pumps to get you the size on them right now, but I am interested in getting advice on Zone Pumps that would be sized correctly anyways.
I have got the Propane company bringing us in a tank and am looking for advice on either boilers, water heaters, or tankless boilers. At this point, I am open to suggestions. I have been looking at the Takagi T-K Jr tankless boiler, but I'm afraid that it wont be able to keep up with all three zones. I am not opposed to running one Tankless Boiler for the large Zone and another for the two smaller Zones, but I have never heard of anyone doing this yet.
Any input on where to go would be greatly appreciated. Everything but the PEX in the flooring is changeable; but I need to get on it soon, as nightly temps are getting in the 40's currently and I would like to get the new system up and running before the slab cools too far down.
Thanks in Advance.
the 'Hopper
Thanks in Advance.
the 'Hopper
