dman535
I have 17" hanging round fixtures in my barn, they are rated to a 200w bulb. Any recommendations on something with good light output that won't break the bank?
I am in middle Tennessee so it doesn't get super cold. My electrical supply place turned my on to some 125w CFL with a 5000K brightness, they were $8 each and seem to be ok for now. I will probably upgrade to some higher wattage units when these go.
Thanks for the info guys.
If you use 4 of those and they put out 5000 lumens each and you have 40x60 feet which is 2400 sq. ft it works out to about 8 lumens per sq. ft. That is not enough to do detailed work but plenty of light to walk around and not fall over things.
Task lighting in the future and you will be OK.
The bulbs are only about 2500 lumens, but have a color temperature of 5000K so they are bright. When these go I might try a 250w set, which will give me about another 1200 lumens per bulb.
