I read somewhere that Victor's stuff is being made overseas?
Here's a cut and paste from another forum:
This would be my oxy reg - a Smith # 40-175-540S Heavy Duty Series 40 Oxygen Regulator w/Gauge Protector, CGA 540 Inlet Connection, 0-175 PSIG Outlet.
This would be my acet reg - a Smith # 40-15-510S Heavy Duty Series 40 Acetylene Regulator w/Gauge Protector, CGA 510 Inlet Connection, 0-15 PSIG Outlet.
But since I prefer propane, this would be my propane reg - a Smith # 40-50-510 Heavy Duty Series 40 Propane, Propylene or Natural Gas Regulator, CGA 510 Inlet Connection, 0-50 PSIG Outlet, and I would add the "Hard Hat" guage protector model # HB190.
And this would be my cutting torch - a Smith # SC929 Gas Axe™ Extra Heavy Duty Cutting Torch, 90° Head - 21" Torch Length (533mm), Cuts Up To 24" (610mm) with Acetylene / 20" (508mm) with Propane
Also, I would have the following;
- Smith flashback arrestors on the regs
- Koike quick disconnects on regs, torch and all hoses except whip connection to first 50', 1/4" hose.
- a 12' or 15' whip hose (which is the first hose connected to torch because that will be the first to get a burn hole in it and it is easy to replace.)
- The whip hose will be hard coupled to a 50', 1/4" dia hose. Quick couplers at extreme ends.
- Extra hoses (as needed) in 50' lengths and 5/16" or 3/8" dia with quick couplers.
-Smith SC50 series propane tips #'s 0,1,2 & 3. (x2 ea.)
- "T" size oxy cylinders
- 100lb propane cylinder
- Tip drill
- Tip cleaner
- Tip Resurfacing Tool
- Triple flint strikers
- #5 shade safety glasses
- #5 shade face shield
- 9 way cylinder wrench (x2)
And that should get you on the "cool" list!
