BTL-A4
I need to run this by you all and get some feedback.
I have a Craftsman 919.167320 air compressor. Because it's so loud, I don't use it as much. I think I have 2 choices: sell it and use battery and/or corded tools, or use sound deadening techniques and get some more useful accessories and use it more. I hate to get rid of it; it has really good specs. CAT makes some really quiet ones, but they have less airflow. Same with Harbor Freight ones.
SPECS:
8.6 SCFM @40 PSI
6.4 SCFM @90 PSI
33 gallon
150 PSI
I measured 85 dB at 3 feet away and 80 dB at 10 feet away (phone app). It's obnoxiously loud.
ACCESSORIES
I have these accessories (*I use the starred ones all the time):
1. *air hose reel
2. *blow gun
3. *tire inflator
4. DA sander
5. right angle die grinder (1/4" shank)
6. 3/8" reactionless ratchet (I never use this, will probably sell it).
7. 1/2" impact wrench (I use this to rotate my tires).
8. small belt sander
9. paint sprayer
10. Media blaster
Here's is where it lives, in the space for the water heater tank. You can see the tankless water heater on the left:
The only other place I could maybe place this is outside in the garden shed right next to the house, but that's pretty crowded and would make it harder to get the air hose in the garage. Still, it seems like a good idea the more I think about it.
SOUNDPROOFING IDEAS
-Intake muffler. Do these really work?
-Insulate the walls with some sort of acoustic panels. Would the ones available at Home Depot suffice?
-Insulate the feet
-Enclose the compressor. I'm worried about overheating and access to the water heater. I thought a wall to the left of it between the compressor and the water heater, along with a door in front would work. Maybe add some air vents at the top and bottom and some sort of fan?
-Move the compressor to the garden shed. It would take up space, but I think I could make it work.
ACCESSORY IDEAS
-I do a little welding, woodworking, car maintenance, and some painting.
-I have battery or corded tools that I use for all these tasks (except painting) that duplicate what I have in air tools. For painting, I go with rattle cans.
-I thought I might get some die grinder carbide burr bits.
-I have the little 2" discs, but these get used up pretty fast, so I hesitate to use them.
-What else would be useful?
I also have a Makita MAC210Q, 2 gallon, 2 CFM@90 PSI, 60 dB (I measured 71 dB @ 3 feet and 62 dB at 10 feet) air compressor I use all the time for blowing out air filters and general cleaning. It's quiet and gets up to working pressure fast. I've never tried it with any of the air tools.
Thoughts and comments welcome!
SPECS:
8.6 SCFM @40 PSI
6.4 SCFM @90 PSI
33 gallon
150 PSI
ACCESSORIES
1. *air hose reel
2. *blow gun
3. *tire inflator
4. DA sander
9. paint sprayer
10. Media blaster
SOUNDPROOFING IDEAS
-Insulate the feet
ACCESSORY IDEAS
