Need recommendations for filling saw cuts
ixlr8
Mid-Coast Maine---> Eastern Shore Virginia
Hi folks, I did some searches but didn't find what I am looking for. I just had a new floor poured for my storage building. The saw cuts are about 1/8" wide and about 1" deep. I plan on using BallistiX Acrylic Sealer Ballistiseal PRO, on the floor. I would like to fill the saw cuts before I seal the floor. I expect to be rolling some heavy tractor attachments on dollies over the floor and I would like for the edges of the saw cuts to not crack and chip when the dollies roll over the cuts. What do folks recommend I fill the saw cuts with. TIA
benjy
Houston, TX
If the dolly wheels are rubber, I can't imagine they'd put enough pressure on the edges of 1/8" saw cuts to crack or chip them off, if I'm wrong, I'd think an epoxy would be needed - which wouldn't expand when the concrete does crack at these control joints.
If they're really small wheels or maybe steel, I guess they might.
I just used caulk on my joints, looks good in some areas, crappy where I was sloppy.
FJ4FUN
NorCal
If you plan on filling prior to coating then be sure to check with coating manufacturer to ensure compatibility between filler and coating, if filling post coating pick a product and go for it!
I
ixlr8
I called the vendor, they said NOT to use any silicon based caulking as their coating would not stick to it. They recommended their 2 part flexible joint sealant.
LiketoFix
OHIO
We always used Sonneborn NP-1, Self Leveling and the Non Self Leveling at the ends to stop it from Running out!
It Lasts a long Time and Very Professional!
LtF
