Need recommendations on insulating a garage door
Eswense
I am curious if anyone has insulated their garage door and if so, what would you recommend. Our garage is located right next to our bedroom and I think that there is some heat being lost through the garage. Living in Fargo, ND it gets plenty cold in the winter and I think that this might be one thing I can do to save a little heat.
I did some searching and couldn't find any related posts so forgive me if I missed them. This is my first post and this forum has been an amazing resource for me.
Thanks for any help!
NUTTSGT
Northern Central Ohio
The old wood doors in my garage, I scrwed some foil faced rigid insulation on to.
Like McDowra said, posting up a pic of what you have will greatly help others help you.
E
Eswense
Sorry for the delay. Here are a couple photos of my garage door. I appreciate the help!
boro_boy70
Whitesboro(Utica), NY
I bought a couple of these kits from lowes and worked fine for me with no glues or fasteners.
http://www.lowes.com/pd_331443-1722...L=?Ns=p_product_qty_sales_dollar|1&facetInfo=
I have the same kits for my garage doors. The double sided tape doesn't hold very well. I cleaned the metal garage door with alcohol before installing and they still come off. I'm going to try to find some kind of glue to glue the clips back on. If that doesn't work, I'm ripping it off and using the foam board. If I had to do it again, I would use the foam board.
Zeke
Eswense, I'm not an energy engineer, but I have dealt with sound and energy issues with door and window insulation for over 25 years. Here's what I have to say about your situation: your bedroom sits next to an unheated part of your structure. What you want to do is keep the heat in the heated part and not worry about the garage.
Looking at your pic, I see what appears to be a garage with no insulation in the walls. I'll bet that goes for the ceiling too. Once energy escapes to that garage, it will not be retained by adding insulation to your metal door. It has too many places to be lost through convection or conduction. There will be a small amount of radiant loss as well, but that gets complicated.
I think your best bet would be to add insulation between the unheated portion and the heated portion even if you have to add a stud wall outside the bedroom in the garage. Make sure your existing wall has insulation in good condition inside. There are ways to retro install insulation in that wall.
Also, if there is a passage door to the garage, make sure it is weatherstripped. It goes w/o saying energy efficient windows help. Lastly, many studies show the majority of heat loss at the ceiling. How is the existing insulation above your bedroom?
If you decide to heat the garage to keep it above freezing, do a total insulation job in that space. And yes, there will be slightly less energy loss through to the garage for each 10 degrees you bring it closer to the house temps.
Insulation slows down the transfer of heat. It doesn't totally stop it.
E
Eswense
Thanks for the tips so far. I should have posted a photo of the rest of the garage. But will try to get to that tomorrow. The rest of the garage and house is actually brick. The bricks are like none that I have ever seen used in that they are about 6 in. wide.
There is Sheetrock on the garage ceiling and insulation blown in above it but no added insulation in the walls. The space right above the garage door definitely needs some insulation.
The rest of the house has brick with a two inch layer of foam and then plaster. Cinder blocks foam and plaster separate the garage and master bedroom. My house was built in the 50's and I was surprised to see the foam in there when a window was replaced.
I'll get photos posted soon of the rest of the garage.
