I picked up a husky a month back for 150. Ten gallons maybe? Actually has oil. Kept up with me laying in 60 3 inch nails consecutively without missing a beat. Like 3.8 cfm. As loud as normal.
Nail guns do not use as much air as the tools he wants to run, I can run my nail guns off a little pancake compressor and would not try to do that with a
cut off saw or impact gun.
The Body Saw and 1/2" Impact are both (35) years old and have paid for themselves several times over. If I had to replace both of them, it's not a real concern. Something more efficient, lighter and quiet would be welcome. I never paid much attention to the body saw's air usage as it didn't seem that heavy although new ones I've looked at are around 8 cfm. I was surprised as my present compressor never worked itself hard to keep up at all. I have no problem looking at a vertical replacement as long as I can find a quality built unit which covers the bases. It would be nice to be 115V as I use the same 220V outlet for my heat in the winter.
My current set-up;
Motoretro
It works OK, just getting a little tired and actually it's very stable in it's present location. The wall standards are industrial grade and the compressor is bolted down through rubber isolation donuts, 1.5" of glued and screwed MDO into HD Industrial brackets. It doesn't move. It's about 3" too tall to put under the bench, that was my first approach before putting it where it is now. I'm not a fan of enclosing a compressor, it needs air to work and stay cool. As far as putting it outside, We have Township Regulations against this as houses are too close together. It's OK inside with insulated walls although I wear hearing protection. I'll let you know where I end up.....
Motoretro[/QUOTe
right. its not an air sealed box. its a baffled box. just like a muffler quiets the sound vs straight exhaust pipes. you might find some ideas looking at portable generator enclosure design.
