tininjun67
Hey all,
I have a 30 x 60 r-panel building and I'm considering using the spray it green foam insulation. I work out of this building so I will have to do it one section at a time as i can't pull all of the stuff and equipment out at once and spray it all at once. A few questions:
1 How thick did you spray the wall and ceiling, and what are your experiences at that thickness as far as keeping temps out?
2 Are there any negatives to spray foam (closed cell) you've experienced?
3 I'm in central Texas and the winter temps are mild, however, some of the epoxy primers I spray require a minimum of 65 degree temp for a minimum of 24 hours. I will need to keep the building at that temp even when it's 30 degrees out. Any advice on foam thickness considering these conditions?
short term future plans include an electric furnace, long term include a geothermal system so i can cool in summer and heat in winter but that will be a long way off. I love the idea of a wood burning or waste oil burning furnace but flames can't be part of how i heat the building.
