So I have a 20 gallon air compress hooked up to a 6ft 3/8" in-feed line, going into a 50ft 3/8 HF hose reel.
I don't have the specs online, but according to the interwebs, the compressor specs:
DeVilbiss Pro 4000
20 Gal
3.5hp
Displacement = 11.9 CFM
8.5 CFM @ 40psi
6.8 CFM @ 90psi
Max Pressure = 125psi
Max RPM = 3450rpm
My impact gun requires 4.7 CFm at 90 PSI. But my gun has very little lug nut removing power. I did find that I was using 1/4 fitting on some of the connector by mistake and has since swapped them to 3/8 fittings.
How can I fix this? I don't think its an issue with the gun, I'm thinking it a hose legth issue. Should I move up to a 1/2 hose? And 1/2 connector all the way to the gun, and then step down to 1/4 at gun air inlet? Any assistance would be appreciated.
DeVilbiss Pro 4000
20 Gal
3.5hp
8.5 CFM @ 40psi
6.8 CFM @ 90psi
Max RPM = 3450rpm
