olytdi
I have a MaxJax with a Trooper in the air. After lifting the car to the top, I went to let her down onto the highest safety stop and one side lowered but the other is stuck in the up position.
I put some jack stands under the arms of the stuck side to off load the weight from the piston/cylinder. So I'm able to get the piston and cylinder free enough to jiggle by hand but I can't get the piston to retract into the cylinder.
When I apply lift power, the not-stuck side moves up but the stuck side does not (it's in the up position a half inch or so above the highest safety stop). When I activate the release valve, the unstuck side lowers normally and the stuck side doesn't budge.
When the weight is offloaded by activating the release valve and resting the unstuck side on the safety stop, and resting stuck side on jack stands, the hose goes limp on both sides. This seems to indicate that the divider valve and release valve are working. If this is correct, then it must be a problem either in the cylinder (binding?) or at the quick disconnect fitting (obstruction?) at the base of the piston.
Two questions: How can I safely get the vehicle down? And, any ideas on troubleshooting this? I don't think I can take anything apart until I get the pressure (vehicle) off the lift.
I suspect it's going to be messy getting this down!
Thanks! I do intend on calling Dannmar Monday morning and it's not a crisis to leave it up in the air until that time -- just changed my weekend plans is all.
