redman43
I've built a workbench in the garage, but now need to extend power to the workbench. I do have an outlet on one end about 6" above the benchtop. That outlet is the last outlet on a GFI outlet protected 15A run (breaker panel -> GFI outlet next to the panel -> regular outlet in the ceiling -> regular outlet on wall above workbench). I want to use a metal box extender with that outlet and then run conduit to several other new metal boxes with duplex recepticals along the 13' length of the workbench, roughly every 3 feet, and a switch on the end of that new run to power overhead lighting in the future once I build some cabinets above the bench. There will be a 90* bend in the run as it is an L-shaped bench. In wall is not an option.
1) Would I use PVC or metal conduit? Does it matter? What are the advantages or disadvantages of either? Cost seems to be about the same. The guy at Home Depot said metal conduit was much more complicated, but didn't get any more specific than that. Part of me wants to use all the same material for the boxes and the conduit because it would look better than metal boxes and PVC conduit.
2) 12g solid, 3 seperate wires, correct? Romex will be too hard to pull through the conduit.
3) 1/2 or 3/4 conduit?
Am I missing anything?
