I'm starting the task of converting my 28 x 21' garage to a workshop. I'm only planning on parking the motorcycle in there. I'm keeping the 16 x 7' insulated overhead door for now. I need to add weather stripping though. I live at a relatively high elevation in central NJ. The house is on top of a mountain, but the property is heavily wooded so wind is mitigated.
I have two questions (so far). The walls are 2 x 4 studs on block. Should I increase the stud thickness and up the R value. I think I can only get R13 from 2 x 4 studs.
Second question: The house is a ranch with a low pitched roof. Although I can use all the storage I can get (no useable attic or basement), realistically anything I put up there once the ceiling is in will likely never come back down.
Should I insulate the rafters, ceiling joists or both?
If I install 2 x 6 ceiling joists where the old ones are now I would have a 9' ceiling. I'm planning on a wood/rigid foam floating floor which will add 2" to the floor, but the ceiling will still be plenty high.
Need some advice. What would you guys do?
