My shop is a 40’x64’x14’ pole building with open steel trusses. The walls and roof are covered with white metal. I believe I have settled on using 4’ LED ready T8 fixtures with LED bulbs. This seems to be a good value and would provide the least amount of glare. I also like that the bulbs are separate from the fixtures. I’m rejecting the lighting options with the led’s built into the fixture because inevitably the driver circuitry in them fails, and then you are stuck buying a different type of fixture because the original ones have been discontinued. With T8 LED replacements, the bulbs should be available for a long time.
My trusses are as shown in the pictures. I have 4 sections, clear spans between trusses. The center two sections have the trusses spaced 16’ apart. The end two sections have 15’ between the truss and end wall. My thought was to hang metal strut between and through the trusses as shown in the picture. The strut is the short green section for mock up, imagine it goes 16’ in either direction. I want the strut to go through the trusses because it get’s the lights above the bottom of the truss. My garage doors are high lifted to close to the bottom of the trusses.
This plan sets up the lights in 4 rows. The two rows closest the walls would be at about 15’ from the floor, and the inner two rows would be at 16-17’ from the floor. I’m spacing the rows fairly equally apart as shown in the drawing. I’ve used the Acuity Brands Visual Interior tool to get some idea of the amount of foot candles of illumination but have not yet been able to figure out how to use dialux evo. My drawing only shows part of the layout, scaled 1’ per square (squares didn't show up on the scan), roughly to scale.
The main question is, should I use 6 or 7, 4’ fixtures per half row? On the drawing I show three options, A, B and C.
Option A uses 7 fixtures spaced 4” apart with a 4” conduit between them, and a 10” space to the end wall. Note that the center fixture goes through the truss, which is 4” wide, so I don’t know if that will cause a shadow issue.
Option B uses 6 fixtures, spaced 16” apart on the center sections and 12” apart on the end sections with 6” space to the end wall. They are still mounted above the bottom of the truss, but none of the fixtures go through the truss.
Option C uses 7 fixtures with the fixtures mounted end to end with no spacing. One fixture goes through the truss. The spacing from the last fixture to the wall is 36”. There is also an 8” spacing between each half row to the truss, I could shorten that a couple inches by increasing the distance to the wall…
Thoughts? I'm looking for some thoughts and ideas to sway me to one of those options...
Brian
Brian
