Need some professional advice (structural)
flashredmkiv
Central Ohio
As was stated in another thread on flooring, we purchased our home almost 2 years ago now. It was built in the early 1900's, so the house has tons of charm and character. When we bought it though, the garage was a mess. The ceiling tiles and insulation were all falling down, half of the lights didn't work, and so on. I have done quite a bit, and am still working on it. It is a single car garage with plenty of room on each side of the car for working. So basically it's an oversized one car.
I have been wanting to utilize the "attic space" in our garage for storing seasonal items and other garage items that don't need to be accessed every day. I was planning to put in an attic ladder, insulating and putting up drywall as well to keep the heat down in the lower part of the garage. That being said, I'm not so sure about the structural integrity of the ceiling joists, which are 2x4's that span about 18 feet. It is extremely old wood, so they are very dense and strong, but it seems that a few have seen their better days (as you can see below):
This one is warped and twisted:
Each 2x4 joist is "supported" up to the roof line 2x4's with some thin pieces of wood:
I know that I need to reinforce all of the joists, but am looking for the best method. I was thinking of purchasing 2x4's as long as needed, one for each side of each joist and lag bolting them clear through. As to how far apart they would need to be, that is also where I'd need advice.
Also, is the method in which they are "supported" up to the roof line 2x4's correct (as in angle, etc)? I imagine I should replace these with 2x4's as well.
I may be totally wrong in all my thinking, but that is why I'm posting in here.
bmwpower
Cracked joists can't be good.
How many inches off center are the ceiling joists?
F
flashredmkiv
Central Ohio
Heck, if I could afford it now, it'd probably best to just tear the whole thing down and start from scratch. Then I could fix the floor and all. Funds don't allow that though.
customperformance
Iowa
My old garage was exactly like that when I started rebuilding it. I jacked up each rafter and leveled them the best i could and where there was bad beams I just layed new ones beside them and nailed them together and I then added new bracing as mine didnt have enough, or any at all on most of it. The floor was cracked and not level either but I couldnt justify a tear out and replace on the floor or garage. I rebuilt, insulated and drywalled the whole thing and then ran new electrical to it with 2 6ft electrical base boared heaters. It didnt matter how cold it was outside I could get it up to 70 deg or warmer and work in a t shirt. I only planned on being in the house 3-5 years and the neighbor hood I was in even if I had built a new garage it wouldnt have made my property go up enough in value to justify the expense. Keep plugging away and do what you can as the funds allow. Now I get to start all over again with the new house and garage. I now have an unfinshed 36'x 37' morton building with 14' walls to finish, this was a win win I got the garage and wife got the house!
danski0224
Near Naperville, IL
You will probably get some good advice here: http://forums.taunton.com/tp-breaktime/
The modern equivalent to those old 2 x 4's is probably at least a 2 x 6- if not 2 x 8. Sistering a new softwood 2 x 4 to the old ones probably won't accomplish anything of structural value.
The attic storage capacity will probably be limited. It is very easy to put too much up there.
