Need Suggestions For Coffee Table Leg Supports
MDSPHOTO
Oz
We have some granite left over from our kitchen and want to use it to make a coffee table and a few end tables for our covered porch. My initial thought was to find some stainless steel legs or table bases and lay the granite on top. Then I thought maybe I should attach some plywood to the legs first and then glue the granite to the wood. That way if we need to move them around we could and it would more evenly distribute the weight. Thoughts?
ModelTBrian
Weld leg together using small angle or flat stock so not to be seen. Make it a sturdy table. Silicone the top to the legs. The granite won't come off.
M
MDSPHOTO
Oz
Unfortunately, I am not a welder, but thanks for the suggestion.
M
MDSPHOTO
Oz
Search "Table legs" on Etsy:
https://www.etsy.com/search?q=table legs
pages and pages of options for ya!
Thanks, there is some nice stuff there. I would guess getting 4 sturdy legs would work for the end tables, but what are your thoughts on support for a 45" x 21" coffee table? Would using some thick ply-wood on top of four legs be sufficient to support the granite or should I add an extra set of legs in the center of the table? Not so much worried about bowing, but rather the granite snapping in the middle of that long table.
rsanter
visalia ca
You can go the plywood route and it does not need to be more than 1/2"
On the larger coffee table I would just use some wood strips under the plywood, say 2x2 as rails to prevent bowing and potentially breaking the slab
Bob
