Need Tips on Removing Broken Tap
rlitman
Long Island
I'd definitely be using the torch..... It is surprising on how the torch will heat just the tap or a broken bolt and to a lesser degree, the metal around it.... The small bits will get cherry hot.
It's less about using skill and more of just a steady hand.
If you are concerned about the process.... Try a practice piece. A long coupling nut, clamp it in the vise, thread a bolt in thru the bottom. Then try burning out the bolt from the other side. Worse case, you are out the $5 for a coupling nut and a random bolt.....
Here's what I've got with regard to pros/cons for the torch.
Pros:
It works, and is quite effective.
It is hard to mess up. Really, it sounds risky, but the tap will heat up in just a few seconds, and it takes many times as long to heat up whatever it's stuck in, so it's actually low risk.
Cons:
You must have an oxy-acetylene torch (we're past that here).
It's not so great in a recessed hole.
And that last one may be a problem. The issue is with exhaust. The whole of the flame is significantly larger than just the visible cone. Against a tap that's flush, or only barely recessed, you won't have any trouble putting the inner cone against the tap. But in a deep recess, the flame needs room for the exhaust to escape, and you may end up with a popping and sputtering flame that won't pre-heat the tap.
Once the tap is pre-heated, only the oxygen stream does the work, and there is no exhaust gas to speak of, so the tap will burn to just about any unlimited depth. But getting it started in a deep hole may not be possible now that it's been drilled.
bulletpruf
San Antonio
Ok, it's done. I got some new carbide burrs in the mail and went to town on the tap this afternoon.
Thought I would end up grinding it all out but it was in there deeper than I expected. Once the factory bolt bottomed out in the hole, I went about another 1/16" and called it quits. Installed a helicoil and called it good.
If I had to do it all over again, I'd probably try the torch -- would have been quicker and less likely to damage the threads.
Thanks for all the input. I really appreciate it.
Scott
Shadowdog500
Down the shore
Scott
No photo! :)
I’m glad you got it done! :thumbup:
rlitman
Long Island
Ok, it's done... Installed a helicoil and called it good.
If I had to do it all over again, I'd probably try the torch -- would have been quicker and less likely to damage the threads...
Congratulations on a well fought and won battle. I can only hope you never end up needing to go the torch route. ;)
bulletpruf
San Antonio
No photo! :)
Thanks! Will have to remember to take a photo today.
Good job dude!
Thanks, man.
Yep. On a related note, I tried the tap removal tools that I got in the mail. It wasn't budging. I didn't crank down on it very hard, however, because I was fairly certain that I was going to snap off one of the 4 small t*ts on the tool and then I would have that to deal with.
Shadowdog500
Down the shore
Those tap removers are kind of like easy outs. They both work great if the bolt or tap isn’t stuck too bad, but they both fail horribly if the bolt or tap are firmly stuck.
